CSVT#49
Addicted CEG'er
I'm just curious on my projector project. I'm going to do a quad projector setup and I'm going to use the Hella 90mm modules. Should I use two low beam 90mm in each housing or should I use a high/low beam combination in each housing. I plan to install HID in the lows at some point in time.
I know Quicksilver, Milan used quad low beam Hella 90mm's and it seemed to work nicely.
But I also know people have used a high beam Hella 90mm.
Are the Hella 90mm High beams better then using the Hella 90mm low beams as the high beam? As the high beam modules do not use a projector lens.
