dfrank
My alignment guy told me he cannot align -- that I need to replace my lower control arm bushings. Left front AND right front. Estimate: $660. $500 of it is labor, because his idea was to remove the control arms and put new bushings in, and then replace. He described in detail how difficult it was to put the new bushings onto the control arm.
At that moment, I wondered if it would be better just to swap in new control arms complete with bushings.
Ok, after checking with a mirror (the guy got kinda strange and wouldn't let me under his lift) mine are the four-bolt type. The kind that are $175, not $75 from the BAT catalog. That's $350 in parts. I was hoping for the $75 kind, but no dice.
Is this something that I (non auto-mechanic) could reasonably do. What would I use to suport the car while I removed the wheel/control arm, etc? Don't want to get killed, is there any danger of sudden spring expansion? Bolt #2 on the drivers side doesn't look like it'll clear the engine. This job looks non-trivial.
Any advice/experiences are welcome. I'll be phoning other shops (San Diego area) for estimates. $660 is a lot of change. $350 is a lot for parts considering BAT will provide four struts and progressive springs for around $500.
