need a little wireing help
epicpwn
Oberlin, Ohio
i bought a svt dash for my car and theres a little green connecter that goes some where one the stearing colum but idk where cant find it hope one of you can help
my guess is it hooks up the the ignition switch so the car will not start untill the cluch is engaged and if there is a problem with the wiring ill change it later but i do not think there will be with the dash harness
got a picture? chances are its the PATs antenna harness.
again, you should not be using a SVT harness in your car. if you're swapping the dash, just swap the dash...
