qbcsvt
I am having a hard time removing the OIL PAN! I got everything unbolted and basically hanging down by a bolt as of now.
When I remove all the bolts holding the oil pan I cannot remove the OIL Pan due to what I believe is the Oil Pickup Tube! The hole within the Oil Pan as I felt my way around it had a bent pipe going into it with an expansion at the end extending the the length or a bit smaller then the hole!
I played with this for about 45 min before giving up! It looks like im getting slack towards the passenger side but not the drivers toward the transmission as it seems to be blocking the way to move the oil pan and remove it. Are their any reminders for a trick for this!!!!
- amyn
- amyn
