97 Contour 2.5L 67,000.
I have had a chronic check engine light over the last year and when I had the codes pulled last year there was only a P0420. Now I have both codes, P0401 and P0420. And of course, its emissions testing time.
After some research here on the forum I was guided in troubleshooting the P0401 code. I used a small vacuum pump that I have for bleeding brakes and put 10psi vacuum on the egr valve, vacuum held steady but engine did not hesitate at all. Pulled out the egr valve and made sure it was opening and not clogged. Led me to believe the exhaust gases were not making back into the intake due to the intake passage being clogged. I pulled off the throttle body and sure enough the passages were completely packed the some sort of carbon sludge debris. After a good cleaning and putting everything back together the engine now hesitates while performing the suck test on the egr valve. I feel this should take care of the P0401 code but now I have to finally deal with my P0420.
I have done a little research so far and am considering the anti-foulers and other such eliminators. My concerns are that with the relatively low miles on the vehicle and such carbon/sludge debris clogging the egr system, I am sure that the car is not running as efficiently and cleanly as it should. I am concerned that the p0420 code is causing the vehicle to run poorly causing a lot of debris the in exhaust therefore causing the P0401 code. I have only had the car a year and have been averaging about 26mpg. My concern is does the use of anti-foulers trick the pcm into thinking everything is ok, or will they actually change the o2 sensor inputs the pcm and therefore how the car is running? Has anybody noticed the use of such devices caused there car to run differently, rich/lean, mpg difference?
Also, does anybody know how long I need to drive for all test parameters in the pcm to ready so when I test I can pass. I've heard they can tell if the codes were recently reset and will not pass you.
TIA.
TIA.
