Aussie Ford
Recontentingthe lighted headlight switch stem:
This feature was removed in 97 or 98; it supplies light to the headlight knob.
To identify a lighted knob you can either remove the knob or check the connector. Connectors with this feature will have four contacts in the center row.
Electrical:
There are a couple of easy ways to obtain the necessary connections:
Harvest a couple of proper size contacts from a donor connector, or remove them and the bezel light from a donor harness and headlight connector. The later is a bit harder since the center row of contacts can be very difficult to remove. I usually harvest them by cutting up the connector to get them safely out. The trick is you do not want to break off the small locking tabs on each side ofthe contact, which help retain it in the connector. Either way below are the wiring parts needed:
To insert the contacts pop out the red center retainer and insert them in from the rear of the connector then replace the red retainer. Pin #7 is the black wire, pin #9 is the white wire.
After inserting the contacts;
If using just the wires you can either solder them to the respective wires on the existing bezel light, or use scotch locks.
if using the pigtail w/ bezel light then cut the existing bezel light off, match the wires up and splice the new wires in place.(my preferred method)
post 1 of 4
Electrical:
post 1 of 4
