qbcsvt
OK so I have or had that INFAMOUS CLUNK in the back by my rear tire.....
and srry it has been a while but I had the chance to do it today. My rear was up on jack stands.(Check the Pictures to have an idea where and what everything is.)
1. Im supposing you got your car jacked up or on a lift with the wheels off already. THERE IS ABSOLUTELY NO NEED TO REMOVE YOUR STRUTS/SPRINGS or even compress them(my car has a BAT Euro KIT)...
2. Remove your exhaust. The subframe is heavy and it will break something as it comes down to the floor.
3. I started in the middle by removing the REAR CONTROL ARMS(as mine were bent and are being replaced) from the REAR SUBFRAME.
4. I then unbolted the LATERAL CONRTOL ARMS(Has a Open C-Section) like from the R.SUBFRAME which are the ones closer to the Gas Tank.
5. I unbolted the LINKS that are on the LATERAL CONTROL ARMS from the SWAY BAR.(This would be a good time to check those bushings, Mine were messed up and are currently on order... You on the other had can be ready for this. They are fairly easy to change at a later time.)
6. Now here comes the EH part. The Four bolts that are holding the R.SUBFRAME up must be unbolted, but be careful that thing will call on your face.. Make sure to have an extra hand, jackstands, jack or something to hold it up, till you have control to let it down to the floor. The SWAY BAR will also come down with it.
Depending on what your setup is going to be or what you are going to do. All my steps are just reversed to put everything back. Make sure to check all bushings and relube everything.
I put on a BAT 21mm Sway Bar with Energy Suspension Bushings, BAT Reinforced Rear Subframe and I replaced my super bent Rear Control arms.
Green: BAT 21mm Rear Sway Bar
Light Blue: R.SWAY BAR BUSHING and Connection Hardware to the R.Subframe
Purple:LATERAL CONTROL ARMS(Looks like a C.) Open C section in stock form)
Yellow:LINKS that connect the R.SWAY BAR to the TUBULAR Control ARMS
Orange: Bolts and nut/washer on other side to remove R.CONTROL ARMS from the R.Subframe.
Black: Rear Control Arms in Red:shrug:
1. New R.CONTROL ARMS painted red.... I got them for free and I kinda liked them.
2. Old bent R.CONTROL ARMS need to be replaced....
3. Old and New BUSHINGS and Hardware to connect the SWAY BAR to the R.SUBFRAME.
4. New B.A.T. 21mm Rear SWAY BAR w/ bushings and Connection Hardware
5. Old " " " " " " " plain
Bottom 4 arrows show where the LATERAL CONTROL ARMS are connected.
Top two arrows show where the R.CONTROL ARMS are connected.
Two circles on each side show the holes that the BOLTS go through to hold the R.SUBFRAME to the car.
Yellow circles show where the SWAY BAR connects to the R.Subframe.
Hope this helps the next person on their clunking issue. GL.
After I bought my REAR SUBFRAME from BAT, I found out Bradness makes them after my purchase or sumthing like that and is the man for all things suspension. To open up your options.
![installed.jpg](http://i211.photobucket.com/albums/bb242/qbshurafa/installed.jpg)
![picturofstuff.jpg](http://i211.photobucket.com/albums/bb242/qbshurafa/picturofstuff.jpg)
![SUBFRAMEalonehow-to.jpg](http://i211.photobucket.com/albums/bb242/qbshurafa/SUBFRAMEalonehow-to.jpg)
