Aussie Ford
When I bought my 99 SE the fella said "one thing I should tell you is it runs out of gas at 1/4 tank." As you may know this is a common problem with the returnless fuel systems. It really didn't bother me too much but since my son has owned the car it is getting worse. We didn't have a clutch to do last weekend and other things didn't workout, so we installed a new to me fuel pump that I've had sitting on the shelf for several years. I just didn't want to do this job....... but the time came when it was needed. Many of you know that I work on the thought that the car in the JY isn't there b/c of the part I'm getting from it and mostly that is correct. Ford has a replacement Fuel Delivery Module for this problem @ about $200. My pump was $10.
DO THIS JOB IN THE SHADE ON A COOLER DAY WITH A SLIGHT BREEZE! this helps control gas fumes at the open tank. DO NOT spend a lot of time breathing them. Max exposure should only be about 3 minutes during removal and installation of the pump. Work Smart and Have Help near by.
First open all the windows then disconnect the battery and the fuel line at the engine. Have a rag ready to catch the fuel that will come out of the line (about a cup)
Then remove the rear bottom seat cushion, and the rubber cover over the fuel pump access hole. Next enlarge the hole using tin snips so you can remove the fuel pump. Remember you will be closing it back up again so do it smart.
Remove the electrical connector and the fuel line (squeeze the sides and pull). Have something ready to catch the fuel about a cup again.
Using a drift and a hammer (I use a plastic hammer to minimize potential for sparks) remove the retaining ring around the top of the pump.
Put on some fuel resistant gloves lift off the top and reach in and grab the pump case, turn counterclockwise. This is to remove it from the retaining tabs on the bottom of the case and the swirl pot. Always becareful as the swirl pot is attached to the bottom of the plastic fuel tank.
Install your new fuel pump, align the screen on the bottom with the large hole in the bottom of the swirl pot and turn clockwise to snap it into the retaining tabs, use a new GREEN rubber seal (stealership item $11 +/-) (I didn't have one) and put it all back together. After closing the hole back up so the rubber cover will fit again, seal the cuts with a sealant or as I did with duct tape.
Below are a couple of pics of the pump. I don't know what the cause of this 1/4 tank issue is but I'm thinking it is a clogging of the filters on the bottom of the case and the inner one on the fuel pump. When I got mine from the JY I cleaned them using some Brake Parts Cleaner b/c I had it handy. Carb cleaner may work as well.
With my gas can in the trunk the kid drove off to see what would happen. He called later to say that at about 1/8 tank a light in the instrument cluster came on showing a gas pump and an arrow pointing to the fill door. There's something I've never seen before ..... at least in that car. :laugh:
AF
AF
