If it has a massive vacuum loss, you should hear hesitation or loping (i.e., idle not steady, going fast then almost stalling, then going fast again).Given everything else is working correctly, what does it feel like when an engine is running rich or lean?
What would be an easy way to artificially (temp) produce a rich/lean condition for testing purposes?
Chris
A slightly lean engine tends to have a light throttle miss or surge, often most noticable in high gear with light throttle. A severly lean engine will be done on power. If severly lean from a bad fuel pump or plugged fuel filter, it won't run at all, starting to fog out at higher engine speeds or under load.
A rich engine runs fine until the plugs foul then you get roughness from fouled plugs.
