Matty K
I'm hooking up a ProForm shift light, and the instructions say to tap a wire coming from the ECU for the rpm input. They list it as pin #48, a white wire with a black stripe. Can anyone verify this?
OK, I finally got off my ass today and figured out the problem. As the instructions say, I cut the brown loop for 6 cyl. operation. Well, thats the wrong one. Through a process of elimination, I figured out that you should cut the ORANGE wire loop only. So, after reconnecting the brown wire loop and cutting the orange one, it works fine. I knew it wasnt my fault!
