So, it's happening to me again. This past weekend has been the worst really. Saturday, if I cranked it long enough, it started. Sunday and Monday, it didn't start at all and had to push start.
To recap everything:
When the car doesn't start, and it just turns over, it sounds normal. (not a slow turn over speed)
The car can be push started
When the car is running, everything is fine as if there are no problems
I only have this issue when the car has been sitting for a while (so, a cold start)
Battery, alternator, and starter checked at the parts store as good (when the car started)
Fuel pump primes
Fuel pressure was fine on start up (when the car started)
Cleaned battery posts and cable ends, took tray out and clean the 3 grounds under there and retightened (only grounds I've touched)
I'm still waiting for the car to not start to try and get some voltage read outs to see what's up. I've had a few suggestions thrown around as to what it could be:
- Ignition switch (still don't think this is it)
- Starter (something about the voltage is too low just for the starter, and not enough voltage for the coil to fire)
- Ignition control module (again, don't think this is it)
- Fuel pump (if this is priming, it shouldn't be it, correct)
