compudude86
so I am starting to convert the LEDS in my door switches/window switches/lock switches. I will be trying to make a tutorial on this for everyone because it seems I cannot find one here already and I feel I should share with everyone wanting to do this.
so far, I've popped the switch apart, poked around a bit, hooked it to the harness with the cover off and probed it with my multimeter (this is a good investment for anyone who works on cars. it is invaluable to see what is going on voltage wise on your cars electrical system and making repairs to it. they sell them at radioshack(expensive) home depot, lowes, i'm sure most hardware stores, I believe harbor freight has them, you can get them almost anywhere online) and I have found what I suspected would be true. the illumination circuit before the resistor shows me 11.9 on battery, and after starting the car, jumps to 14.4 volts.
"12 volts" is no longer the case for the cars illumination circuit. back in the day, when everything used filament lamps, 12 volts could and would vary and wouldn't be an issue as the lamp was good for about 5 volts extra give or take before it would burn out. Im also going to take a stab at the possibility that older cars/alternators ran lower voltage as well but I could be wrong. However, with higher power alternators driving higher power ignition and controls under the hood it has become the norm to see around 14 volts in the car.
so what happens if you go ahead and use resistors matched to 12 volts? I can speak from experience. first few days, they will run great. as the week goes on, your LEDs will burn out completely, one by one, or you will see them begin to "hyperflash", or flicker on and off, then start to blink really fast and dim, right before they go out for good.
on my setup, I am compensating for a voltage of 15. will this dim my LEDs some? especially when the car is off and the voltage drops to 11.9? probably. but I guess it is a small loss compared to spending all that time soldering and replacing LEDs just to have to tear it all apart again to replace burnt out or flashing LEDs.
