As the title states my SVT is down. 2K with lets say 60,000 (about 20 shy) mi. Anyway I was at SHOgoFast's (Adam) yesterday helping him with his car, went to leave turn the key one click and nothing else. So here's what's going on
Turn key, one click
Tried jump starting, no difference, still one click.
Lights dim
Will not turn over.
Can starts (quite easily) by pushing and popping the clutch
Tried the 3rd gear rock (to eliminate teeth on teeth between starter\flywheel)
Clutch switch seems to be working, since without the clutch pushed in you get nothing, pushed in the click.
Searched CEG found another thread very similar (same problem) pretty much everyone was saying the starter was the problem, but OP never posted back with solution.
Nearest auto store picked up a reman starter w\solenoid (all they had), installed, same problem. Roll started it, went home.
All grounds are clean and secure, battery is putting out 12.65V, everything seems to check out. Engine runs smooth, no funny sputters, idling, nothing out of place. Pulled in driveway at Adam's, shut her off, and that was that.
So what did we miss, if anything, all suggestions are welcome, I REALLY do not want to take this to a shop if at all possible. All fuses and relays dealing with ignition seem to be in good condition (no broken wires visible on fuses) pulled relay, click stopped.
Turn key, one click
Lights dim
Will not turn over.
