Tips an axel circlips
andreslobo
Idyho
After many tries installing my left axel shaft, hitting my hand several times with a hammer, I finally listened to the guys at the transmission shop and installed a new circlip and it popped right in. It appears that the circlip gets burrs on it and this prevents an easy installation or removal.
or
Tips on axle circlips? :laugh:
The axle circlip should be replaced ANY time the axle is removed. Not replacing the circlip can cause serious damage to the diff. if the axle is not seated properly.
