rexxdoggy
Okay, I talked with CSVT#49 about his experience with them. He told me the following.
"The front struts are not coilovers. All they allow you to do is expanded or compress the coil springs to obtain the ride height you want. What's the problem with that you ask?... simple, you compress the coil spring so much to get the correct ride height in the front and the spring is no longer a spring. It just becomes a spacer as at this point the springs are compressed so much that the coils in the spring touch each other. As you drive down the road the coils in the spring are grinding into each other (even if you don't have it compressed all the way). Not sure if you went to SZ last year, but the other memeber that had the Ksports was bragging about how the stance of his car looked... that was until I pointed out to him that his coil springs were compressed so much that he was grinding the springs, at which point he said oh... so that's what that noise is. This is the main reason why I sold my Ksport kit and went to the BAT kit."
I'm looking for a few things. One being pictures of the fronts to those who have them installed right now, and two, to those who have them and who used to have them, did you have this same experience as CSVT#49?
