create what appears to be white smoke? or at least it appears white through the tint on my back window.
I do know that some oil is dripping at two different points onto the header wrap. One is at the oil pan and the other is from the turbo drain. both are seaping alittle oil, but not a hugh amount.
what I see happening is when I get into the boost, say rolling into 5th on the highway after I let off I get a cloud of white smoke. I haven't noticed this at 3 psi, except for alittle coming out from under the hood after running it really hard. anything above that it will.
Now there is no smoke under normal driving, only when running in boost. The coolant level hasn't changed and the oil level is still good despite the slight leaks. Does not appear to be signs of oil in the coolant and the oil doesn't smell funny like there is coolant in the oil. The idle is perfect, water and oil temps are perfect and so is the vacuum at idle. When I checked the plugs the other week they where fine also.
I did read some old posts that suggest this is oil burning off the header wrap. I do belive this is what is happeneing as I sometime smell burning oil when this happens. I haven't had anyone follow me yet so I don't know if this is coming out of the exhaust or from under the car. And like I said it only happens after running in boost which of course is going to heat things up more then normal.
does anyone else agree?
