Posts: 279 |
I just took my car to the dealer to get the coolant system pressure tested. I have a slow leak somewhere, and need it fixed so I am not making Walmart rich buying coolant. Anyways they call me like three hours later and the guy tells me that the mechanic can't find a leak. He then proceeds to ask me if I have any ideas
Posts: 2,382 |
Are you dripping coolant somewhere? Any puddles under the car?
If not it could be a gasket issue (which isn't good).
"Fear is the little death."
Muadib.
Posts: 346 |
could be the t stat o ring.
Posts: 1,788 |
If it were, there will be coolant pooled on top of the tranny.
You'd think a dealership wrench would have looked there...
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 1,459 |
head gasket?
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 103 |
Originally posted by nasty1: I just took my car to the dealer to get the coolant system pressure tested. I have a slow leak somewhere, and need it fixed so I am not making Walmart rich buying coolant.
Most dealers will inject a dye in the cooling system. After the car has run for a while, they then use infrared goggles to spot where the coolant is leaking out.
My Mystique recently had its 2nd water pump replaced in a year. It started off as a slow leak then progressed to the puddle-on-the-driveway-and-engine-overheating stage over a period of 3 months.
Obviously there's no certainty that this is your problem, but judging by the number of list users who have had to replace their water pump fairly regularly it seems like a pretty good bet.
/Eric
Ottawa, Ontario, Canada
'96 Mystique GS, ATX
