I used a LUK Pro Gold Clutch Kit and I can break the tires loose into 3rd gear and it doesn't slip, this is done while holding the gas pedal down even while shifting. I believe it is equivalent to stock. Good pedal feel also.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
