I agree, there are only two ways to remove the oil pan. However, when you drop the subframe, you have to be careful putting it back. If there is any sort of shift in how it was installed before, it may ruin the cars alignment. Loosening the passneger motor mount and removing the front motor mount is much simpler. But good luck with changing the pan.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
