can any one tell me the torque per lbs on the low crank housing? thanks
98 svt contour, magnaflows, sho shop intake, sho shop high flow cat, no pre cats, custom cougars short shifter, 3 liter hybird engine woo hoo im happy, and just added a dmd underdrive pulley.
Why are you re/building and engine without a factory manual?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
i do have the manual but i just had to make sure if i was tq in it right cause it seem low on lbs tq. and do i need to use new bolts on the bottom end also?
AUSSIE ENDLINKS $70
AUSSIE ENDLINKS $70
im pretty lucky the engine block is reusable and the cylinder heads.
