Posts: 15 |
gj4eva
Posts: 6,791 |
Super charger
No real luck on contours...
Posts: 15 |
apart from a junkyard, where else could i get a 3L motor? i thought svt contours only came in 2.5L? kinda new at this.
gj4eva
Posts: 7,025 |
Originally posted by geejay4ever: thanx guyz, $5000 for 40horses more? not gonna do it!
thats wheel hp, not crank.
236 whp is ~ 287 crank hp
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 6,791 |
Originally posted by geejay4ever: apart from a junkyard, where else could i get a 3L motor?
Tons of great info here Here
Originally posted by geejay4ever: i thought svt contours only came in 2.5L? kinda new at this.
Correct
Posts: 1,593 |
Originally posted by geejay4ever: apart from a junkyard, where else could i get a 3L motor? i thought svt contours only came in 2.5L? kinda new at this.
I'm certainly not an expert, check out the 3L pages...
The SVT Contour's only came in the 2.5L V6. When they are talking about a 3L they are talking about a 3L Duratec from another Ford, like a Taurus or Escape, etc.
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 15 |
just went online n found that aizdynochip has a 3L short block already prepped for $1800. i'm assuming its ready to go. good deal?
gj4eva
Posts: 6,791 |
Check out this thread, it'll give you some ideas.
Posts: 9,872 |
Originally posted by geejay4ever: just went online n found that aizdynochip has a 3L short block already prepped for $1800. i'm assuming its ready to go. good deal?
its not ready to go, it'll take like 2 months for Rick (Buckshot77) to build it up then send it to you..
Posts: 1,029 |
It'll also need the heads, cams, etc. attached. That's why it's a short block. Not trying to be insulting, just making sure you don't expect to just bolt it straight in. Scott
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
