If it is a squeeling sound, it could be a loose belt or tensioner.
If it is shrieking metallic sound, it could be the compressor clutch.
If it is a groaning sound, then check power steering. Check fluid level (reservoir on the passenger side strut tower). If level is fine, try bleeding it.
Power steering bleeding procedure.
Fill reservoir to max line. Start engine, turn steering wheel from lock to lock a few (maybe 5) times. This should purge the air in the system. If steering is still noisy, turn off ignition and leave vehicle overnight (maybe 10 hours). Then repeat the bleeding procedure again.
