The swaybar end link(s) is the most likely culprit. Can't hurt to replace the swaybar bushings too. The endlinks are about $12.50 each at fordpartsonline.com and simply bolt on at each end. Replaced them on my 96 and all front end noises went away.
I did the hose mod using reinforced tubing that is usually used for water heaters. But the clunking turned out to be a loose brake caliper. Both fixed now- very happy those noises are gone.
And it only cost me $3.74 for the tubing and hose clamps...
