Originally posted by dellowm:
Try switching the O2 sensors from location to location, post cat or pre cat on each bank and see if the codes reappear...
The pre- and post-cat O2 sensors in this case are different parts with different plugs. Not to mention accessing the upstream sensors (bank 1 in particular) is hardly a trivial exercise.
What was the exact trouble code (P####)? Some primary causes of running lean would be an air intake leak downstream of the MAF sensor, inadequate fuel pressure, or faulty MAF or O2 sensor.
Which of the four O2 sensors did you have changed? Why did the previous owner replace ALL FOUR sensors? Your post brings up many questions...
