Page 4 of 7 1 2 3 4 5 6 7
#461017 10/26/02 03:51 AM
"Absolut Rara."
"Absolut Rara."
DO NOT, I repeat DO NOT make any attempt to remove your speed limiter without replacing your tires with ones with the appropriate speed rating. Running tires for higher speeds than they are designed for is an excellent way to kill yourself.
Balance is the Key. rarasvt@comcast.net
#461018 10/26/02 03:08 PM
How much did it cost you to have the pcm redone? thanks
1998.5 Contour 2.5 v6 atx power everything maroon
#461019 10/26/02 07:36 PM
E
E
if you guys are gonna go more than 90 mph, do me a favor and let me know, so i can stay off the roads? seems more than a little stupid to me.
now officially a troll, i guess. used to have a black 96 SE, until it broke down one too many times. now I'm hunting for a motorycle.
#461020 10/26/02 10:12 PM
I believe I payed a little more than 100$ CDN.
-Jeff -"Buck Futter!!" My Ride! http://members.sounddomain.com/sideoftheroad
#461021 10/27/02 10:11 AM
I am Canuckian
I am Canuckian
Originally posted by AirKnight:
Originally posted by mbb41:
On another note on my first high speed run when I ran into the governor I made a mistake. Not at the time knowing at what point the governor was set up at and running out of safe stopping distance. I clutched in only to stall the engine @ aprox 185kph. When the governor kicks on it retards the fuel supply. I time this perfectly to screw myself. No engine power = no power brakes or steering. I almost made poopie of myself. I slowed down as needed but not without a near heart attack.
Why the hell would you clutch in at that speed? During high speed runs, I always brake first, then if the rpm gets too low I put in the clutch. BTW, even if the engine is off you'll still have a pump or two left in the brake that's power assisted. That's because the brake booster is still basically a vacuum.
I was kinda planning on coasting for a split second to take in the full effect of that speed without the noise of the engine. Point of the story was to show to others what happens when you do this.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#461022 10/27/02 11:30 PM
I want to wear a PARACHUTE before I would run my Contour at 110
I guess I am from the old school
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX *New TORQUE CONVERTER @ 53,000-Intermittent P1744 *New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
#461023 10/28/02 03:51 AM
i hate governers!!!!! my 91 s10 would run right around 140-150 range, not fully sure cause i had to have someone follow me in their stang with an aftermarket speedo to get an idea cause mine only went to 85, but that was a rush man 140 down a highway in maryland. i want my tour to do that, and yes i do have z rated tires, and had them on my s10
98se, cheap exhaust-hopefully soon the brullen, hella rs bodykit and eibach's and koni's soon, 17" konig persuits, falken 512 215/45/17, lots more to come, anyone with a pre 98 trunk pm me if you can get rid of it. aim name is konig17se98
#461024 10/29/02 09:57 PM
Funny thing happened to me. Driving down the highway and my speedo went out, found out it was the VSS Cable. After that when I hit the speed where the gov. normally kicked in I felt a slight hesitation and then it picked up again and didnt slop climbing until I slowed it myself. didnt know how fast i was going (since the speedo is out) but i was pushin 7k RPM's.(this was all on the track of course). I still havent put the VSS cable in.
98 Contour SE Sport w/ MTX K&N Air Filter FlowMaster Exhaust Removed Resonator Universal GTR Type C Wing Shaved door handles Custom Paint 16" Chrome Rims Dropped
#461025 10/30/02 12:58 AM
In reply to:
Clutch was slippin,, huh ?
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#461026 10/30/02 01:51 AM
That's like the idea of how I got rid of my speed limiter. Except I don't loose the speedo because I have cable driven VSS.
