Posts: 980 |
Whenever I have replaced the rotors on cars, I always use some type of rotor cleaner, usually whatever is cheapest. My father is telling me that I can just use simple green and some of the blue shop papertowels that we have. Is he crazy or am I blowing money on something I don't need?
2000 Mystique LS
Duratec 2.5L MTX
Posts: 6,910 |
put new rotors on my mystique the other week, father just washed them with soap and water, then after they were on the car I also wiped them down with brake cleaner to make sure they were clean after handling.
anything that will remove the protective coating will work
- 95 Mystique LS - Zetec/5spd
Posts: 5,854 |
all you really gotta do is get rid of any grease/oil or brake fluid you might have gotten on them from installation, the heat from the pads contacting the rotors will take care of the rest. I've never heard of any "protective" coating though.
1999 Silver Frost SVT
#609 of 2760
Posts: 6,910 |
coating is when they are new so they don't rust from sitting in a warehouse
Posts: 4,639 |
i used denatured alcohol to clean my new rotors and all is well
Hugo AIM:omegazodiac
Posts: 862 |
Yeah like they guy above said, just make sure they are grease and oil free. Dirt won't really matter since they get dirty as soon as you drive.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 2,779 |
As brapple said, they have a oil on them to avoid rusting while sitting there. Just shoot the crap out of them with brake cleaner. You don't want to go out to test them and not stop too well because they're oily...
Posts: 18 |
I just use dishwashing soap in warm water. I scrub them with a nylon brush and dry them off with compressed air. Works just as well as commercial brake cleaner but lots cheaper.
Mike
My Toys:
99 Contour SE Sport V6 ATX
76 F150 Ranger XLT 460 V8
79 Bronco Custom 351M V8
Posts: 198 |
-1998.5 Contour SE V6 ATX.
PM me to tell me of a welder that can craft me a modified Y pipe in the Los Angeles area! OR I may be willing to buy a 3 flange modified Y.
Posts: 2,779 |
Originally posted by montanaoffroader: I just use dishwashing soap in warm water. I scrub them with a nylon brush and dry them off with compressed air. Works just as well as commercial brake cleaner but lots cheaper.
You can get brake cleaner for as low as 99 cents....spray on, dries itself, with no residue left over. You can't get much easier or cheaper than that.
