Posts: 3,045 |
credibility was questioned and was in return verified. no more need to question that. just wait and see what kind of power he puts down, how well it hooks up and whether he starts breaking parts. good luck is offered.
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 1,190 |
I need mazda 6 exaust cams!!! IF anyone knows where to get them let me KNOW ASAP please... I want to build this beast right..If someone finds them anywhere please pm me. Thanks Brian
Pics of manifold and pistons are coming shortly...
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 1,190 |
SLICK SHIFT MOD BY TERRY HAINES
#702 of 2150
Posts: 1,190 |
ââ?¬Ë?SLICK SHIFTââ?¬â?¢ SELECTOR FORKS FOR THE MTX75.
As we all know using the latest Ford Focus shift forks can smooth out gear shifts. HMS Inc has gone several steps better.The Ford forks use roller bearings on the 1st/2nd shift fork,an improved oiling ââ?¬Ë?gutterââ?¬â?¢ on the 3rd/4th shift fork,the 5th/Reverse fork is unchanged from the original 1995 design. To improve shifts and reduce friction & wear HMS Inc ââ?¬Ë?Slick Shiftââ?¬â?¢ Forks feature:- *Roller bearings on ALL forks. *Added lube oilways on all forks. *High load/friction areas are ceramic/M0S2 coated. *Shift fork shafts are coated. *Our coatings can take up to 300,000 psi loads.
#702 of 2150
Posts: 10,015 |
Originally posted by obicanobi0: Originally posted by Stazi: Originally posted by svtProdigy: also i have these, came with axles.
Hmm, asymmetric bearings. Interesting...I wonder why they did that.
Can you see any numbering on the bearings at all, letters? Aslo please tell me the inside bore diameter (use calipers). I want to see if I can find some info about those.
What do you mean by asymmetric?
the inner races are not symmetrically split, i.e. the split does not run down the middle of the width of the bearing.
BTW - those are Audi wheel bearings...I'm trying to get a print of them (in the SKF vareity). SNR is a small French bearing company.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,190 |
Picture of the updated shift tower from a ford focus...
#702 of 2150
Posts: 1,190 |
#702 of 2150
Posts: 1,190 |
#702 of 2150
Posts: 1,190 |
#702 of 2150
Posts: 1,190 |
Carrier bearings...
#702 of 2150
