Posts: 1,066 |
I want to buy a SVT TB to optimize but this looks kinda fishy .. especially with that svt decal Can anybody confirm that that is an actual SVT TB ? Thanks
Posts: 5,854 |
Originally posted by ODC: Why does this "SVT" TB say 3.0L ?
because they all do...
1999 Silver Frost SVT
#609 of 2760
Posts: 1,368 |
Yupp, that sticker is usally hidden under the accoridan tube. Saw mine this weekend when I had my intake assembly apart again.
Posts: 1,572 |
You can tell from the throttle cable ,if it pulls from up TOP then its SVT it it opends from the bottum its SE , each car had a diffrent setup.
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Posts: 4,760 |
Originally posted by josh_: You can tell from the throttle cable ,if it pulls from up TOP then its SVT it it opends from the bottum its SE , each car had a diffrent setup.
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 1,578 |
Originally posted by I-Dom-In-8: Originally posted by josh_: You can tell from the throttle cable ,if it pulls from up TOP then its SVT it it opends from the bottum its SE , each car had a diffrent setup.
My car pulls from the top and it is an SE
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 4,693 |
The 3.0 throttle body casting is used to make the SVT throttle body. The 3.0 and SVT are the same diameter (60 mm).
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,066 |
Originally posted by 98_HO_Contour: Originally posted by I-Dom-In-8: Originally posted by josh_: You can tell from the throttle cable ,if it pulls from up TOP then its SVT it it opends from the bottum its SE , each car had a diffrent setup.
Sooo is this an SVT unit ?
paging DemonSVT or some guru ....
Posts: 4,292 |
...........ummmm i'm pretty sure the last six post plus this one confirm it...the 3l and the svt use the almost the exact same tb..the difference is on the bottom of the 3L tb theres a cutout for the iac valve...yes its a svt...you'll find anything that is diff from non svt to svt will have a sticker..lim,tb,even the struts have a big "SVT" sticker on them.....buy it optimize it and be happy....ITS A SVT TB!!!
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 10,015 |
Originally posted by ODC: Originally posted by 98_HO_Contour: Originally posted by I-Dom-In-8: Originally posted by josh_: You can tell from the throttle cable ,if it pulls from up TOP then its SVT it it opends from the bottum its SE , each car had a diffrent setup.
Yes it is.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
