Page 2 of 2 1 2
#1330344 07/13/05 07:36 PM
#1330345 07/23/05 02:59 AM
Originally posted by 2X95SEs:
On mine the 30 amp fuse holder in the fusebox was half melted internally which pulled the contact leg away from the fuse.
Can you give me the fuse number (from the owner manual)? I am having similar trouble... my A/C will work fine for a day or two, then quit for a day or two... then work for a day or two, etc.etc.
I've never heard of this melting-fuse holder problem, and I have a suspicion that it's causing my problem too.
Thanks
KSandbergFL
1995 Mystique YA, V6, manual
198,500 (will be at 200K by end of August!)
#1330346 08/04/05 04:23 PM
Took my car to a local electrical shop. Turns out the "load switch" was bad. The load switch is supposed to cut-off the A/C compressor if the psi goes below 10. I had plenty of freon and pressure, but the switch was still shutting off.
Got billed $20 for the part and $105 for the labor. Not too bad... my A/C blows cold enough to make ice cubes now - hurray!
KSandbergFL
1995 Mystique YA, V6, 5sp
199.6k miles
#1330347 08/04/05 04:35 PM
KSandbergFL
199.6k miles
Thanks for posting the solution. This will help us in the future when we do a search.
Page 2 of 2 1 2
