Posts: 21,197 |
From Terry...
...I've had mine in MY contour since 35,000...car now
has 128,000 on the clock...no changes.The Ford data
sheet for testing states the lube must stand up to a
min of 100,000 shifts without breakdown or wear to the
syncro blockers that would cause a crunch
shift...FWIW....
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
Originally posted by todras:
$45!!!!! Not $60!!!!!!! About $15 a quart.
Originally posted by Rishodi:
That's if you're lucky. And it's still too damn expensive!!
What do you mean if you're lucky? From fordpartsonline.com
Item Number MSRP Core Price Price
XT-M5-QS $17.29 $0.00 $12.97
$12.97 a qt plus shipping is $46.86
-'96 SE MTX 3L
Posts: 6,760 |
watching you two bickering is...
Ryan
Trollin!
Posts: 21,197 |
Hey he wanted to come in here and post. His fault for being illogical. Nice new glasses mang!
-'96 SE MTX 3L
Posts: 4,141 |
Originally posted by SvtEdwardo420: ok my tranny blew about 4 months ago and i was running redline, now i took it apart yesterday after seeing this thread is still going and there was not a spec of black gunnk or any sign of anything , and i was runnign it for about a year. so what else could cause that???
-i think it was accidently missed at the bottom of the page as no reply was made.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 584 |
Pretty friggin' cheap compared to a new transmission with a blown stock diff. now isn't it?!!!!!!!!!!!! If you're that much of a tight ass put in regular Valvoline ATF in it! $3 a quart.
Nah, I'd rather not use ATF; that's why I was looking for a good mid-grade alternative between that and the honey. By the way, I'm getting tired of the "cheap compared to a new transmission argument". That's moot. I should be able to drain and fill my transmission with a good lube without spending too much. I'm used to $3-5/quart, and I'm not the only one that thinks the Honey is overpriced.
I don't doubt that you CAN keep Honey in the transmission for quite a long time, but I wouldn't do it. Hell, some people *cough* have kept the stock ATF in their Contour until after 100k miles and I wouldn't have done that either if I could help it. Ford's honey is no miracle fluid; it's still transmission fluid, it gets dirty, and it needs to be changed every so often.
However, I'm glad to hear that it's available for $13/quart plus shipping. That's cheaper than I've ever seen it and beginning to look like more of a reasonable choice.
E0 Silver Frost CSVT #3095/6535
Alpine CDA-9851
Posts: 584 |
Uh oh, what's this? Someone else running MTL and found no signs of the sludge?
To answer your question though, quite simply these transmissions were not as well designed as they could be. After a few years of wear, the differential and the synchros are prone to give out. It's not at all an uncommon issue.
Alpine CDA-9851
Posts: 21,197 |
Originally posted by pole120: -i think it was accidently missed at the bottom of the page as no reply was made.
Oh we saw it but I don't see him posting any pics of his transmission. He could be starting flamebait. Seeing his posts in the SE MI regional forum I don't trust most of his posts.
-'96 SE MTX 3L
Posts: 21,197 |
Why are you tired of it? Because it's true? You buy a 23k SVT and can't part with $45 every 4 years for a fluid change. With an estimated average yearly mileage of 12k. What is that $11.50 a year that breaks down to? Do you use synthetic Mobil 1 in your SVT like most on here do? (Probably run the $1 a qt stuff from the corner store huh?) If you do it yourself it's about $25-30 an oil change every oil change every 5k? Makes the trans fluid sound like a bargain eh and your logic wack now doesn't it? Should have bought a Yugo.
-'96 SE MTX 3L
Posts: 21,197 |
Originally posted by Rishodi: After a few years of wear, the differential and the synchros are prone to give out. It's not at all an uncommon issue.
Umm NO! I had 130k when my 2.5 spun a bearing. My stock MTX looked great when I had a Quaife installed!!!! Big Jim has 200+k on his SVT without any motor or tranny work. Proof that aggresive maintenance works. Nice try on that angle though.
-'96 SE MTX 3L
