Posts: 5,810 |
What do you mean challenging current information and us jumping up and down?
I don't think anyone has professed to know what the new taurus injectors really are. I think Todras has said that the Escape inj. are 19# and the newer Taurus are 24# but that wasn't carved in stone. I know my Taurus injectors are 24# because I looked up the part number. So really, until we get some serial numbers and post the list again, I don't see this as anything other than a bit of good, added information.
See My Mods
Posts: 1,210 |
I flowed the escape and taurus injectors i had and they turned out to be 19 and 24 respectively
John, if you want I can send you over my chip since I'm not driving my car and you can try it out?
Ohh and as far as I know the ford dealers don't have flow rate infos
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 9,602 |
I'm one of the folks that has posted a few times the Ford manual stated the newer returnless 3L 4V injectors were 21lbs. This even as recently as last week or so IIRC. There was also a big post about it quite a while ago started by a NECO member. (he posted a scan from the manual but I don't know what year or model)
I've had no problems with tuning mine (from an 02 Taurus) and have my injector slopes at 24/28. My final A/F is nearly identical to what I am commanding with the fuel tables. Of course I have the cat temp switch off and a couple other "fuel" nannies.
I don't see anything wrong with running 21lb injectors on a 3L because you are never going to max their potential Normally Aspirated. However I do agree you need to know what size they are to program for them.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,943 |
well since i have my fuel rail off for leaking issues and since i also have tuning issues with adc, ill post my PN's here:
the ones i have currently on my 3L:
YL8E-B2A
and another set i had on a spare motor:
YF1E-A2C
so if anyone knows what size those guys are let me know...
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 375 |
What year and model did the engines come from?
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
Posts: 1,943 |
Originally posted by 5speed3.0SE�®: well since i have my fuel rail off for leaking issues and since i also have tuning issues with adc, ill post my PN's here:
the ones i have currently on my 3L (01' taurus):
YL8E-B2A
and another set i had on a spare motor (00' taurus motor):
YF1E-A2C
corrected*
the 3.0L
Posts: 1,210 |
This is another one I know
YL8E-C7B (2004 Escape) 19 lb/hr
Watch me go
Posts: 1,943 |
YL8E-B2A
YF1E-A2C
i just had these two different injectors flowed....
YL8E-B2A these flowed 19 lb/hr
YF1E-A2C these flowed 25 lb/hr
hth in getting a list compiled...
the 3.0L
Posts: 310 |
Originally posted by 5speed3.0SE�®: just had these two different injectors flowed....
These were flowed at 45 PSI for anyone who cares.
I'll put holes in him!!
Posts: 5,810 |
See My Mods
