Originally posted by Y2KSVT: Received!! Thanks Steeda!! Now where are those directions?
Mark
Ok heres the directions, Sorry no pics but its simple.
To Remove the rear deck carpet, remove the 10 push pin plastic peices, the seat back lock plastic peices and the middle seat belt cover.
disconnect the third brake wire if applicable.
remove the rear deck carpet.
Take mount and hold it up to the hole centering the subwoofer over the hole. drill either 2 holes for the 10 or 4 holes for the eight all the way threw the rear deck.
Then mount the sub to the bottom of the board.
then drop the bolts threw the board and put a washer on the bottom and the nut. Might need to use vise grips to hold the top of the bolt while tightening the nut. until its into the rear deck. for the 8 do that for all 4 bolts.
for the 10's use the 2 Self tapping screws and run them into the beam that runs across the rear deck.
Reinstall is reverse but make sure you run the Third brake wire.
