Posts: 122 |
Just a side note... Make sure you dont have a bad brake hose. I've seen them collapse inside and act a a one-way valve and not let the fluid back out of the caliper. Happened on one of my former cars. Burned out two sets of bearings, brake pads and calipers before I figured it out.
For Sale 98+ SVT gauge cluster
'98 Mystique LS
2.5l 5spd
Posts: 8,445 |
yeah, good point. the easiest way to check for that is to crack open the bleed screw and then try to puch the piston back into the caliper. if the piston moves in and fluid comes out od the bleeder, then you have a swollen hose...and not the kind that chicks dig.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Smurfette
Smurfette
Posts: 8,770 |
I checked - no leftover brake pads. sorry
Kim
1995 Contour GL
Needs less "needs more"
Posts: 9,872 |
so no one has neither used pads nor rotors around me?
Posts: 8,445 |
Posts: 1,593 |
Originally posted by Goonz SVT: so no one has neither used pads nor rotors around me?
I am headed to a j-yard tomorrow. If something from a non-SVT will help you let me know, and I'll see what they have.
I just don't know the differences between the rear brakes from the SVT to other models.
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
The rear rotors/pads are the same for SVT and non-SVT vehicles.
Haroon, I may have pads and rotors, I'll take a look after work today. I don't remember if I kept them before I moved or not. But, I'll check.
Chris
NJ
98.5 SVT Silver Frost
Posts: 9,872 |
Originally posted by Shaggy: The rear rotors/pads are the same for SVT and non-SVT vehicles.
if you do then let me know, Bill messed up my order AGAIN so instead of having the caliper in today as we agreed on, I'm gettin them Monday
Posts: 4,051 |
Originally posted by Goonz SVT: Originally posted by Shaggy: The rear rotors/pads are the same for SVT and non-SVT vehicles.
What else would you expect from Team Ford?
Posts: 7,431 |
Que?
I didn't know Team Ford was so disliked here .. ?
