OK this is what I have. This is for a stock 3 liter. What do you have?
Desktop dyno
Bore 3.5
Stroke 3.130
Cyl 6
Cid 180.7
Heads
4 valve head/ stock ports and valves
Valve size 1.316 intake
Valve size 1.099 exhaust
Compression ratio 10.00:1
Cyl (cc) 493.5
Comb/ space 54.8
Flow 320 cfm
Intake manifold. Tuned port injection
Exhaust manifold stock manifolds and mufflers
Camshaft
Seat to seat
IVO (BTDC): 18 IVC (ABDC): 52 Lobe center angles 108.5
Intake Dur 250
EVO(BBDC): 61 EVC(ATDC) :21 Exhaust Dur 262
INT valve lift (@valve) .988 Intake centerline angle 107
EXH valve lift (@valve) .988 Advance/retard 0
My max HP is 205 at 5500
max TQ is 226 at 4000
