Page 8 of 9 1 2 3 4 5 6 7 8 9
are you running a set of headers? maybe thats why. my manifold never glows. perhaps its the metal of the ex. mans on 2.3T cars.
as long as that A/F is staying low *12.5ish* it sounds cool to me.
1985 SVO: 4 cylinders, 5 gears, 20 PSI
1998 torredor red SVT contour: #3705 of 6535
need info on your SVTs service/recall/warranty history? e mail me...
Originally posted by bnoon:
Is there any chance of offering the headers to the collector and down pipe as a piping only kit for those of us with a DIY attitude? I've got the fueling and engine control figured out, can add a intercooler later, and have access to to many turbo parts to want the full kit. Not to mention, stage two of project Silvinator just might flow to much for a T28 anyway... Just asking...
Chris, I was thinking the same thing as Brad is now building my low compression 3.0. Do I contact you on costs for just piping? I'm doing some reading on turbo availabilities and types now (well, for a while now laugh ) and I'd like to add my own. I'm tossing methanol injection in the air as cooling and raising octane content and keeping head loss to the throttle body to a minimum.
Will StreetFlight be doing this for us? Thanks!!
ChickenhawkRacing@hotmail.com
1998: #4415/6535
mods: Sheet metal screws in rear chrome strip
Four wobbly corners
"Hey, do you like apples?"
"Well, yeah."
"Well, I got her number, how do you like them apples?"
Don its not the header, its the turbine housing[exhaust side]of the turbo. Don its nothing to worry about, its normal and besides you can only see it at night so its not like its so hot its going to melt. All turbo's do this with prolonged high RPM driving. The turbo is THE restriction in the exhaust, so of course more heat collects there. wink
Suggestion from the peanut gallery #58374.
How about making the part of the exhaust that is "exposed" replacable without welding, flanges, gaskets and what not. For those of us you think speed bumps are good ways to test suspension travel...
Scott
96 SE, MTX, BAT 22mm rear anti-sway bar, BAT springs and Spax struts
96 Caprice, 9C1
Rayon is made of wood!!!
hmmmm, mine doesnt... maybe i should go with more than the 20 PSI i am using?
sounds like someone needs a bigger exhaust housing, or a bit of porting... wink
My car has been delivered to Street Flight. Will post pics as they become available.
Looks to be a clean install, who did the work on that part of it? Also where is the intercooler at, pardom my ignorance on this one wink
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
Roger-
The silver box to on top of the turbo is actually a smaller radiator(intercooler) that circulates water through it. It then goes through a heat exchanger in the lower grill and then back to the resovoir tank that I have in the trunk. I can add ice to the tank to really improve the intercooler effect. HTH
If it's true that we are here to help others, then what exactly are the others here for?
Whoo Hooo,
Guess that means my turn is coming soon wink
TB
Tony Boner
I can't wait to drive my car with boost and hear that Turbo XS Blow Off Valve smile
