Posts: 403 |
I recently got back from a trip to Mackinaw City, Michigan and I got 28 mpg highway. Not to bad considering I was averaging 78 mph and nothern Michigan has a lot of small hills form Grayling to the bridge.
96 Sport 2.0L - 190,XXX miles
Posts: 1,016 |
I average about 25. Some highway/country road (3/4) while the rest is a mix of city, and town driving.
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 1,145 |
Originally posted by SilvaSVT98: that sounds about right... 200miles w/ a qtr tank left. thats what i get. Our tanks are if i'm not mistaken 14 gallons, when you fill up (i fill up at around 240 miles) thats just flirting with the gas light coming on, i usually have 2 gallons STILL in the car because i usually end up paying for 12 gallons. so instead of dividing your total mileage by 14 (the size of our tanks), divide by 12 and that should give your a smoother, not so rough estimate.
i divide the miles by the gallons i put in on a fill up not the gas tank size. If we all get this terrible mileage how did the EPA get there Numbers cuz they are way different
98.5 Black SE ATX
Posts: 2,353 |
I believe the tanks are 15.4 gallons or so. There seems to be debate over the size, but I have filled mine multible times with over 15 gallons. Usually I just figure on about 40 miles after the light comes on. Oh, and I average about 23mpg with mostly highway driving.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 9,602 |
23-24mpg in mixed driving with a VERY lead foot. 0-60 time trials every stop light. Okay maybe I skip one or two. Tops! I have seen 28-30mpg in straight highway cruising at a set speed (70-80mph) I've never seen below 20mpg even in testing and racing on a full tank.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,475 |
Demon, you must live in the boonies or something to get away with the driving you speak of Not for us suburbanite dwellers unfortuantely ... I'm currently seeing about 280-300 miles/tank in mixed driving. Thats with new plugs/fuel filter, clean UIM and TB, and dirty LIM and (filthy)stock air intake. Once I clean the LIM and put my new intake in, Im sure my high speed mileage will improve, at speeds where the secondaries are open (above 80 mph) and airflow is important.
Posts: 36 |
According to most sites, the spec is 14.5 gallons on a tank. I think if you're getting more than 15 gallons in the tank, you should report that gas station because you're probably getting ripped off.
There have been a couple of times where I was at a cheap gas station where I thought I was putting in a little too much gas because I hadn't thought the gas gauge was reading that low, but I've never really put more than 14 gallons in. I think it's also bad to run your tank so low that you need it fill it all the way up, I'm told that it burns out your fuel pump prematurely as the gas is used as a heat sink to cool the pump.
Oh, and I've always gotten around 20 mpg, sometimes 22 mpg when there's a lot of highway.
'95 Contour LX
V6 ATX
Posts: 1,308 |
I get about 320 per tank and thats when im on empty with all city driving. on my 4 banger atx. Is that good for a 4 banger?
97 Mystquie GS - I4 ATX died at 168K
94 Pontiac Crap AM SE - 2.3L I4 5spd
2002 Mazda Protege5 - 2.0L ATX
Posts: 103 |
thats what i said in my post, divide by 12 (usually the amount you fill up if you waited last minute to do so).
Jeff Silva
E0 Contour SVT Silver
-STEEDA PEDALS
-K&N Drop In
-Ford Racing Wires (w/Bosch +2's)
-Cleared Headlights
-Yokohama AVS ES100's
-Alpine CDA7893 w/MBQuartz
-EUROLITE 9006/893
Posts: 9,196 |
On freeway trips I get anywhere from 28-30 mpg and locally it varies from 21-23 or so The best I ever got though was 30.6 mpg...I know, I'm a geek
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
