Suspension Modifications
Koni Adjustable Struts
Eibach Lowering Springs front
H&R Lowering Springs rear
24 MM Aussie Bar- Rear Sway Bar
¼ Metal sway bar backing plates
Poly end link bushings
ES Motor Mount Insert
245/45/16 Yoko AVS Tires
5 MM spacers at rear wheels
Tubular Steel Adjustable Rear track arms
From Buckshot Motorsports
Energy Suspension Rear Control Arm, Front and Rear Sway Bar bushings
12.2? Superlite Brake kit from TCE Performance
11.25? Upgraded Rear Brake Kit from TCE Performance
Cryo Treated Brake rotors by 300 Below Inc.
Drivetrain & Performance Modifications
BNM prepped 3 liter block
SVT Cams, w/ water pump drive removed
Cunningham Chrome Molly Rods with upgraded rod bolts
Clevite 77 rod & federal mogul main bearings
Dual Mode Mondeo Damper
SHO Shop lightened Billet Flywheel
Crank Knife Edged and motor balanced by Horn Race Engines
Pistons, crank, and rods cryo treated by 300 Below Inc.
3 Liter Heads Port & Polished with multi-angle valve job by BNM
Port matched UIM and LIM
RAM Clutches Kevlar Pucked clutch and HD pressure plate
2000 Model Year Transmission
HMS Inc. Mark III transmission update w/ full lube system & Zetec Final Drive Ratio
Quaife LSD installed by HMS Inc
Driveshaft Shop level III CV shafts
Cryo treated wheel hubs and studs
42 lb Ford Racing Injectors
MSD DIS-4 ignition Control
Water Injection Kit
Accusump 2 qt accumulator
Remote mount oil filter
Apex-I SAFC
Ford 9MM Plug Wires
B & M short Shifter
75 MM Pro-Flow MAF
65 MM Throttle Body
2.5? True Dual Exhaust w/ Magnaflow race series mufflers and crossover
Custom 1.75? Nickel Plated headers by MSDS Inc
Vortech Supercharger w/ upgraded shaft and 2.87? pulley
Custom water to air intercooler by Buckshot Motorsports
Autometer Phantom gauges including A/F Ratio, Oil Pressure, Oil Temp, and 5? monster tach w/shift light.
4 point Safety Harness
Dual Honed SVT upper intake
Trunk mounted battery
Aesthetic Modifications
BNM Polished stainless sill protectors
Removed door ding guards
Foglights run w/o head lights
BNM Indiglo Gauges & HVAC Panel
Powdercoating of Various engine pieces by BNM
Billet Pedal Kit including dead pedal
15% window tint
Body color matched grilles at all locations
Painted SVT Emblem at hood grille
Custom Front Fender Badging
SSR GT1 series 16? Rims
PIAA 510 Driving Lights
Front Splitter by Mirko Racing
Sponsors
Brad Noon Motorsports
Cunningham Rods
MSDS Inc.
RAM Clutches
TCE Performance
300 Below Inc.
Wolfe??s Auto Body
I haven't updated it for a while but currently the price just in mods not including any labor is $24,000
Come on who here can give me a run?!
