Stazi,
I'm interested in the links. Right now I have no sway bar (I bought yours and it broke the mounts). I'm planning on soon dropping the subframe and doing the weld on fix. Since you're the sway bar man (YOU THE MAN ), do you have a good detail on how to make up and weld some heavy duty brackets? Gimme some good info on this and i'll prolly buy your links.
98 SVT T-Red. 17" Borbets w/GY Eagle F1 GS-D3's, Koni/Eibach setup, urethane suspension bushings. Aussie Bar. Battery in trunk, open K&N Filter. B&M Shifter. Gauge pod w/ volts, oil pressure, oil temp. Sparco drivers seat, Schroth harness belt
