Posts: 4,970 |
I'm going to be able to slide in by the final deadline. Now....do I have to skim it in by the first....or before the end of the business week??
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 4,713 |
Rick made it sound like he was pretty darn flexible with dates.
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 1,469 |
I just picked up an UIM for $24 (including shipping!) off ebay...so looks like I am in if early July is OK.
Think I will email Rick to clarify exactly HOW a non-honed, small port UIM will come out same as an SVT UIM..if he tells me they are going to Hone the non SVT part more aggressively then that would probably motivate me to send the non SVT part for Honing. If NOT, then the SVT part goes..
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Posts: 3,496 |
Originally posted by Dan Nixon: I just picked up an UIM for $24 (including shipping!) off ebay...so looks like I am in if early July is OK.
Get back to me on this Dan. I too am questioning the validity of this GB as the Duratec Performance forum has vague flow numbers for SVT UIM's.
People say the UIM SE ports wont match the SVT's including the TB opening. All very interesting and I'm still lost on how $320 is getting me 13cfm or 23cfm?
Posts: 1,423 |
See my post in Duratec Performance "00SVT vs. SE pic's". I spoke to Rick at EH a good bit Monday about the whole process. He had not done a SE UIM yet so he couldn't say too much but sugested that I compair the two before I make a decission to send a SE instead of the SVT UIM...I sent the SVT UIM
Scott
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
I am Canuckian
I am Canuckian
Posts: 4,168 |
I do want to get in on the action but can't justify it at this point. I do however have an extra se UIM lying around. If someone needs to borrow/buy it let me know.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 1,469 |
No response but Scott got pretty much all the answers..posted in the EH post in "Performance".
Since they would run the SE manifold longer, it would presumably flow the same as if an SVT were used to start.
Looks like a potential problem with the t.body opening..on the SE UIM, it may expand into the EGR opening with the Honing OR be too small for the SVT t.body (a must for all with this mod)..Unless we know FOR SURE that the SVT t.body will work with the SE manifold I would not send it.
So, anybody modified an SE manifold to fit SVT t.body?
Posts: 7,117 |
I've got an SVT TB housing. I could bolt it on tonight & take a picture to show the overlap at the manifold. That should show us how much material would be taken from the manifold if an SVT cover plate is used to perform the EH.
I'm curious to see if the EGR passages are exposed with the SVT TB in place on an SE UIM. I don't think I'd like that. If the difference in the actual TB openings is small, I don't think there'll be a problem. You guys know the measurements. Take 1/2 of the difference and compare it to the thickness of the material adjacent the passages.
Posts: 773 |
sending mine in today. i wrote my return info in permanent marker all over the top of the manifold because im polishing it afterwards anyway. cant wait to feel the difference over my stock myst manifold.
Posts: 1,423 |
Guys be sure to check out the Jet-Hot GB interest check SVT ST Pete and I are setting up...UIM's can be Jet-Hot coated for $77 plus shipping if the GB happens. With 12 or more we get a 30% discount off the regular cost of $110. I think Extrude Hone will send you UIM directly to Jet-Hot if you like according to Rick at Extrude Hone. This may save a few bucks off you shipping?
See GB for more details...
Scott
Scott
2002 F150 SuperCrew
