Posts: 8,143 |
they still kept your cat? have any pics?
Posts: 5,621 |
Well, is some CEGer/Zetec'er gonna test them NECO headers?
Posts: 7,117 |
Soon as they're available, I'm sure that somebody will bolt em on. Should be any day now...
Posts: 2,974 |
Originally posted by ZetecNinja: they still kept your cat? have any pics?
Nope, I bought a magnaflow universal cat ane then cut the pipes on the cat to make it a bit shorter and so it would fit in the factory location instead of relocating it to under the car. I have pics of the header installed but it's kind of hard to see the cat, let me know if you still want the pics.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 8,143 |
yea I wanna see...I'm pretty curious.
I guess if you have a header like the zxtuner one that comes in 2 different pieces you could add a cat after and then have a custom downpipe made.
I didn't know shops would mess with your cat.
Posts: 7,117 |
If you have none, it's OK for them to install one. If you have one failing, they can replace it. Removing them is a big no-no.
Posts: 8,143 |
ok so if I install my own headers but then see them to have a cat welded in thats no problem?
guess you learn somethin new everyday.
Posts: 2,974 |
I'm away for the weekdn put I will send u a pic as soon as I get back. My headers look like the escape headers (that funky deisign that comes up from the block) if you go to CTA Motorsports webpage and look under the foucs you will see the header its called the edelbrock shorty header.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 8,143 |
oh yea a shorty header...I kinda would rather have one of those...would make it easier to add in a cat too.
but didn't you have to do some welding to the cat? I'm assuming it doesn't bolt on to the flange on the shorty?
Posts: 2,974 |
Originally posted by ZetecNinja: oh yea a shorty header...I kinda would rather have one of those...would make it easier to add in a cat too.
Yes I had to modify the cat for 2 reason. 1) the focus flange is a triangle and has 3 bolts and my mystique flange was an oval with 4 bolts soI got a machine shop to make me a focus flange becasue I couldnm't find on. 2) the magnaflow cat was to long so I chopped the pipes on each end of the cat by 1inch and then I got it angled so it fit in the factory loacation which aloud me to keep the downstream o2 sensor in it's factory location(I didn't feel likw splicing and extending it). The exhasut shop will also have to put a bung in the header and inpipe just behind the cat so you can put your o2 sensors back in.
Aaron
AKA NVS SVT
Yeah it's modded
