fordman302
Ok so who here as bought a Nautlius CAI extension?
Have you noticed anything in throttle response? considering buying one..
if i'm going to trouble joey to send me anything, it's going to come with a turbo in the box hahah
i just got my kit, i am in the middle of painting it as i type this. (drying)
Plus its really really cold outside right now. Since i never drive my car during the winter, i am going to make an acception for about 10 mins to see how this intake feels.
You will be driving a car you normally don't, in weather you normally aren't used to.... any change may be perceived rather than real.
Not saying it won't make a difference, as I believe it will.. just saying..
Subscribing---hoping to hear install stories and feedback.
I believe Joey said he'd be posting dyno results with IATs soon.
Planning on ordering one this spring.
-J
This is probably going to sound like a dumb question, but will this Cold Air intake pipe fit with the BAT straight pipe between the T/B and MAF or would you have to replace it with the stock accordion tube again? (I believe the old picture on the site showed it with the stock rubber tube and the new one just shows the components)
Thanks
The hose offered has some slack between the maf adapter and tube extension. So it will work with a bat pipe etc. He likes the rubber hose because it keeps intake temps cooler than what the bat pipe can do.
IIRC the bat pipe is jet hot coated to help out with that though...
But it doesn't compare to plastic though. Plastic doesn;t heat up as much as aluminum can. Go out to your car on a hot day and put your hand on the intake hose after running it very hard in hot weather. Now go do it to aluminum. See the difference. Aluminum can absorb more heat than plastic can. In simple terms
Its a very good reason why gm,ford etc switched intake manifolds to plastic over the years. Plus its easier to do plastic injection molding sometimes.
Harry
Did you get your CAI on and run the car yet?
