So, thanks to some help from this forum, my '95 Mystique V6 is back up and running. To recap quickly, the alternator had died, and I replaced the regulator, as when I pulled the alt it tested bad. Unfortunately, there was apparently something wrong with the alternator ITSELF, as when I put it back, it ran for a while... and then started putting 17 to 24v into the system.
At one point when I was trying to figure out what was going on, the horn and lights went with the car off, and the speedometer jumped to 120mph with the car sitting still, tach went backwards, etc...
Took the advice I got here and put an entirely new (well, reconditioned, or whatever) motorcraft alternator in, along with a new megafuse.
The car now works great, except for these things:
-My Pioneer head unit is dead
-The LCD clock is dead. You can see the time, and it responds to button presses, but the backlight is gone.
-The electric mirrors don't work.
-It clicks whenever you press / release the brake - the same click you get when the car is sitting in park and locks out shifting until you're holding the brake. Except now it does it all the time.
I checked the 'radio' fuse visually when I realized the HU was dead, and it appears to be fine - though I didn't put a meter on it. I checked a bunch (but not all) of the other fuses, and none were gone.
The rest of the car seems to be fine (windows, interior lights, power locks, gauges, etc).
Any ideas? Is there one thing that would cause all this oddness? Or am I seeing the few things that got killed independently during the 24-volt massacre?
