guys you all need to chill out.
now the op said the oil isn't on top of the plug. ie its not on the threads of the plug. to the op is this correct?
if there is oil on the plug but its above the threads then its the valve cover gasket. but if the op is seeing burn oil on the plug threads and the tip of the plug then its something else.
op please confirm.
after that I would suggest a compression test and a leak down test. also how does the coolant look?
op please confirm.
