Knock Sensor
Unplugging the knock sensor can cause your car to run more timing and produce more power, the gain depends on the calibration of your stock PCM....this does no/little good for those running NGP0.
The vibration from the head is enough that it makes the sensor think there is knock when it does not, at 6,000rpm the PCM turns off the sensor and the timing that it pulled gets dumped back in, you can see it in dyno's:
http://memimage.cardomain.net/member_images/6/web/414000-414999/414152_9_full.gif
Here is that same run as above(the red one/CWQ3) vs NGP0 and no knock sensor:
http://www.altecxp.net/host/NGP0.bmp
The jump at 6100rpm is the timing being added back in. If the car does not knock after 6000rpm, it will not knock before 6k rpm and is safe to disable, how ever this is only recomended on cars that do NOT have raised compression or forced induction. 89 or 91+ oct may be required.
