Titanv6
Is it possible to advance the oem cams on a 2.5 V6?
there are versions of the duratec with VVT variable valve timing ..... that is the way ahead if you need cam timing adjustment ....G.
mazda jaguar and lincoln ... i think ....
if you google duratec VVT it should bring up some results.
A few people have toyed with the idea of converting to VVT but no one has actually done it .
If you are serious, it would be good if you started a build thread and showed your progress .. ..... G.
