Am looking at possibility of changing the ecu on my 3l st24 to the st 200 ecu apparantly the ecu is the dame part number.. i will get the lockset. Ignition barrel also what else do i need to make the pats work. Will i need the pats ring on the steering column. What part is the pats module . Is that the same as the alarm and central locking module
how can i tell if the pats module is built into my ecu or seperate module
