First make sure your cooling system is up to par. I like to do a couple runs of 50% water and simple green to clean out the
inside (drain, add simple green, run for 20 mins, repeat). For summer I like to run more water than anti freeze since water runs cooler (about 10% anti freeze just enough for the water pump to have lubrication). Bigger e-fan will definitely help, a thermostat that opens earlier (i used to run with a gutted thermostat), foam all around the fan shroud to keep everything air tight. I'd prop up the hood in the back by adding washers to the hood bolts so hot air can escape (lower windshield is a high pressure area).
Most importantly would be water/methanol injection. I used a spare fuel pump and spare fuel injector (550cc), put the injector right near the throttle body, run a hose from that to the fuel pump in a spare coolant resevoir, wired up that fuel injector to my secondaries injectors (only comes on during boost), wired the fuel pump to my aux input on my ECU, and it worked great. Lowered my air temps by almost half. No bogging or nothing. Of course the fuel pump and injector eventually locked up, because it wasnt meant to pump water. I'll be buying some meth injectors and water pump especially for WI though.
