Why would you want to?
The computer controls the fans more efficiently than you can.
There are very few reasons a person should ever change their fan setup they got from the factory.
1: Overheating, insufficient air flow.
2: Space constraints due to turbos or other hardware that interferes with the fans.
3: Changing from a mechanical fan to an electric fan.
4: Putting on something for pretties, or to be JDM TYTE YO. (though one should never do this.)
If you are looking into dual fan setups to increase CFMs, you can still wire it into the existing harness that runs your two speed fan. It is basically just adding a couple relays so that on low speed one fan is on, on high speed both are on, and on A/C, only your high speed side is on unless the temperature gets too high.
But, IDK what dual fans you would want to use.... Any idea what the CFM on the zetecs fan is?
If you do go with a switch, just use a 3 way switch, wire one side to run a single fan, and wire the other side to run both fans. That way you have less switches to deal with.
Hello.
The reason I had to rebuild my engine all over again is because it overheated due to poor air cooling. I've upped my compression to 12:5.1 therefore I want to have a better airflow. I have changed my thermostat to a 180 degree Failsafe so that should also help.
From what I understand , the computer controls the fan when the temperature is to high. Maybe 200 degrees or more. It looks like the dual fans that I got will connect straight to the harness for my single fan . I don't know the CFM on these dual fans (I got them from the junk yard from a 98 , 4 cylinder zetec car..the one with VCT)but they sure seemed to blow more air on both low and high when I bench tested them versus my single fan.
I'll get a better picture of when the computer turns on the fans from my aftermarket temperature sensor which I installed in the upper radiator hose. If they do not come on around 190 degrees , I'm definitely hooking up a switch to control them whenever I want based on my aftermarket temp. gauge.
So yes , I will let the computer control them but want a way to mannualy turn them on when I want to. In the summer it gets pretty damn hot and I don't want to risk another blown head gasket , melted piston , and warped head because of a dumb stock temperature setting which the computer works on. I also know that both fans either turn on at the low setting at the same time or at the high setting at the same time.
Can I turn both fans on low than on high with a 3-way on-off toggle switch?
I'll post a picture for a better understanding. I could be wrong about the relays though.
Fans that I got. When both of these wires connect to the + on the battery along with the ground cable to the - , both fans work on the high setting. When only one wire gets connected to the + along with the ground cable to the - , both fans come on at the low setting. My schematics might be off on the high setting as well as the relay ones.
Fan diagram. I don't know for sure if I need to connect to those exact wires from under the relays. I need to check which 2 activate the fans.
