BurritaSVT
I discovered a welded spot with two large pits on it. And I found my silcone 90 degree hose lose i could find out why my boost would not hold up. I noticed it got worse where I could only get 10 psi then I knew I had a problem I found it the d@mn hose was loose going to the Throttle body. I am curious now how long this been going on I will test it tomorrow if it holds 15 psi across the board watch out we may get another run to pick up some lost air. Wish I could have seen that before the dyno.
