1998 CSVT 3L Swap
1998 CSVT 3L Swap
1998 Contour SVT $2495
3.0 V6 from a 2004 Ford Taurus.
5 Speed Manual Transmission.
171k Miles on Car (Taurus Motor installed @ 148k Miles)
All replacement parts were FORD/Motorcraft OEM unless otherwise noted.
Motor/Trans
2004 Ford Taurus Motor had 77k when installed, currently has approx 90k
5 Speed Manual Transmission with 130k on Rebuild.
New Clutch Kit installed @ 148k Miles (Included Pilot bearing, Clutch Disk, Pressure Plate and a New Flywheel)
New Power Steering Pump, and associating adapters @ 165k
New Plugs, Wires, Upper Intake Gaskets @ 169k Miles
New DPFE Sensor @ 171k Miles (MasterPro Brand)
New Radiator @ 148k Miles
New AC Condenser @ 165k Miles
Body:
New headlights @ 148k Miles
Replacement Fenders, Headlight Panel and Hood (all Ford)
New Windshield (Had chips and a Crack in it) @169k Miles
Suspension:
New Springs All around @ 148k Miles
New Control Arms @ 148k Miles
New Control Arm bushings @ 148k Miles
New Ball Joints @ 148k Miles
New Sway Link End Bars @ 148k Miles
New Rear Control Arm (Passenger side) @ 156k Miles
Interior:
This SVT has Midnight Blue Leather in Decent shape with only a small tear (about ¾ of an inch) in one of the back seats.
Midnight Blue Carpeting
Tinted Sunroof with Vent/Shade Slider
Power Drivers Seat
Power Windows/Locks
Key Fob Programmable (currently does not have them)
Car Audio:
Car currently has a Sony CD player with Kenwood 240W Speakers in the doors.
A 600w Amp on a pair of 400W Pioneer 12” Subs in the trunk
Replacement/Extra stuff for the car
I have a large collection of Interior items (Weather stripping, complete dash, extra Gauge cluster (139Kmiles) and other MISC Body/interior items that will go with the car. I would bring a truck, it will not all fit inside the car.
This car is showing its age, and has a few things that any buyer should be aware of.
Body:
1 Side Skirt has some damage from the previous owner
Drivers side ¼ Panel has a dent in it. (Vehicle was rear ended, bumper and support were replaced)
Suspension:
Needs Strut Mounts, and a Drivers side Tie Rod end.
E-Brake cables are loose, and worn. Need replacement.
Engine:
Needs a Replacement EGR Valve (causing IDLE to hang between and after Shifts)
Interior
2 Pieces of Interior Plastic have broken clips.
Power Antennae no longer works (Cable broke, motor still works fine).
Joe
Jmcmahon82@gmail.com
or
PM me Here
or
Call me @ home 651-494-8005
Edits: Done in Italics.Things I forgot
There are a few more pictures detailing/Close up on the rear 1/4, Side Skirt, and the front bumper.
They can be found
Here
